ASA 5505 DMZ config question - CLI
Nov 12th, 2007
I have recently inherited a network with an ASA 5505 at a remote office. Users there have a server that needs to be accessible from the outside. I would like to put this server in a DMZ and use port forwarding (I have the security plus license already installed). I can only find the ASDM instructions for this - there has to be CLI commands for this. Can someone please respond with either the instuctions or the link where I can find them?
JORGE RODRIGUEZ Mon, 11/12/2007 - 09:03
Will you be using the ASA outside interface IP? if so this thread should get you up and running for port forwarding , replace your static entry to reflect DMZ interface , static(DMZ,outside) etc.. , come back if any questions.
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Security&topic=Firewalling&CommCmd=MB%3Fcmd%3Ddisplay_location%26location%3D.1ddfc9dc
kwhitley1 Mon, 11/12/2007 - 18:59
First of all - thank you - both for your response.
Yes - the ASA outside interface IP will be used for the server as well.
Here is what I have created so far
An Object-group:
Object-group service SERVER tcp
description TCP Passthrough Ports
Port-object range XXXX-XXXX
Port-object range xxxx-xxxx
Port-object range eq xxxxx
An access list outside_access_in:
access-list outside_access_in extended permit tcp any host (outside IP) object-group SERVER
And applied this access list to the outside interface:
access-group outside_access_in in interface outside
Is this correct?
Would the static look like this?
static (DMZ,outside) (outside IP) (DMZ server IP) netmask 255.255.255.255
Do I need a global (outside) statement?
JORGE RODRIGUEZ Tue, 11/13/2007 - 05:24
your static should look as :
static (DMZ,outside) interface netmask 255.255.255.255
for global leave as is if Im not mistaken it should already have statement as " global (outside) 1 interface "
msosabar Mon, 11/12/2007 - 09:32
Here is an example of the configuration guide for PIX and ASA version 7.2, check it out and use for further reference.
