33.6 Kps fax rate with ATA's
Nov 12th, 2007
Will a fax machine with a fax modem speed of 33.6 work with an ATA? I know ATA's can't handle more than 14400 bps. So will the fax machine automatically "reduce it's speed" down to what the ATA can handle?
SBCdd7343 Mon, 11/12/2007 - 10:04
Am I correct that even though the fax machine has a fax rate of 33.6, it will work without issue at lower speeds (which will be manually set on ATA)? Or do some fax machine not work at anything below default fax rate?
thanks
SBCdd7343 Mon, 11/12/2007 - 11:23
Last question. I know that FXS ports will work with G3 faxes. Will the VG224' allow for 33.3 fax rates?
