Policy NAT over VPN
Nov 12th, 2007
Pix 525, OS 7.2(3)
I am trying to do the following:
Inside FTP-server 10.1.1.1
Outside NAT-address: 20.1.1.1
Remote Network: 172.16.1.0/24
VPN connection from remote network to outside NAT-adress that should be redirected to inside FTP-server.
I am trying to use the static command like this:
access-list Crypto_map extended permit ip host 20.1.1.1 172.16.1.0 255.255.255.0
access-list FTP_OVER_VPN extended permit IP host 10.1.1.1 172.16.1.0 255.255.255.0
static (inside,outside) 20.1.1.1 access-list FTP_OVER_VPN
The translation just don't work. Are there any better way to do this? I need to use Policy-NAt since i do not want the FTP-server to use the translated address any other time than over the VPN-tunnel.
david.barroso Thu, 11/15/2007 - 04:45
I have a similar scenario but in my case I'm specifying the service:
My ssh server: 172.17.3.4
NATted IP: 172.23.133.4
access-list 112 permit tcp host 172.17.3.4 eq ssh object-group EDS_NETS
static (DMZ,outside) tcp 172.23.133.4 ssh access-list 112 0 0
In this case my DMZ network overlapped with another vlan in their side so I natted my host. I am not sure if it is necessary to specify the service to work. Have you checked that you do not have other static matching the host before the policy-based static rule?
