11-12-2007 09:29 AM - edited 03-05-2019 07:22 PM
Hi everybody,
I've got a 6500 series router here with a 48 port module and was wondering if there was anyway that i can test that all the ports were functioning without having to physically plug them all in. Any help would be useful - it's running off of catOS.
11-12-2007 01:10 PM
Hi, you can simply issue " show test X " where X is module number.
you should get line card status as (. =PASS, F= Fail ) on each of the ports.
Rate any helpful posts
Jorge
11-13-2007 03:15 AM
Thanks for that. How do i rate your post?
11-13-2007 09:34 AM
Hi, when reading the message look at lower end right corner for "Rate this post" , thank you in supporting the ratings.
Rgds
Jorge
