Backup Fail on Callmanager 5.1
Nov 12th, 2007
Hi, i need you help. I can't to make a backup. The follow message appear:
ERROR: Error, unable to move tar file to: /common/drf/2007-11-12-14-25-28/2007-11-12-14-25-28_SUB-LAFARGECH_CCM_LOCALE.tar,
Pls.see the attachments.
Any idea?
Pablo Roman Reinoso Mon, 11/12/2007 - 16:00
Hi Cristian,
Have you installed the Locale in both or all servers Pub and Sub? How many CCM do you have?
andres.pasten Wed, 11/14/2007 - 09:08
I`m working with Cristian in this instalation. I`ve loaded locale and moh files on both servers, and error still appears.
andres.pasten Mon, 12/17/2007 - 14:37
I've made an upgrade to CCM 5.1(3) but it didn't resolve the problem. The message error is the same.
On you post you've said it's a bug, but the ID doesn't work, can you check again the ID?
TIA
andres.pasten Wed, 02/13/2008 - 06:33
We solved this issue with a TAC Case. The upgrade was to 5.1.3-1000 and then I've uploaded again the locale.
When the CCM synchronized the DRS, the issue was solved.
I hope this works for you.
Andres
