Get Caller phone number from 7960
Nov 12th, 2007
How do I retrieve the phone number of someone calling a Cisco 7960 phone connected to a router and that has a PC connected to the 7960, using it as a internet connection.
I am looking for a solution that can be integrated with a visual basic application.
Anonymous (not verified) Fri, 11/16/2007 - 11:59
Do you have callmanager in place or the router is running as a CME? If callmanager is there you can get the report of calling numbers from CDR.
mrdaveshaw Fri, 11/16/2007 - 12:51
I do not have callmanager, nor do I know what a CME or CDR are. My setup is using a Linksys router connected to my DSL modem. The Cisco 7960 is connected to the Linksys router and my PC ethernet is connected to an aux port in the 7960. There is no other software related to the 7960 installed on either the router or the PC. The 7960 connects to the VOIP provider and I have a test account with them to use. The phone works perfectly. I just want to know how I can get the phone number from the 7960 from the PC.
Thanks for helping.
