Diego Vargas Tue, 11/13/2007 - 07:27
  • Cisco Employee,
The CSS is able to balance the traffic at layer 4 (just looking at the ports), so there should be no problem.
The trick is to give the correct TCP port numbers.
About RTP/RTCP, I am not familiar with the protocol, but if it works with TCP, then here again, the correct port numbers should work.
Hope it helps!!
Branimir Turk Wed, 11/14/2007 - 10:25
I agree about TCP, but it seems that RTP is using dynamicly assigned ports.
Diego Vargas Wed, 11/14/2007 - 11:02
  • Cisco Employee,
If the ports are not always the same you can have the CSS configured with a layer 3 rule (listening for any TCP port).
