Pix 506 Configuration
Nov 12th, 2007
I have a Pix 506 that I'm trying to intergrated as a perimeter firewall.
I've looked over the config and see no issues yet I can never get any inbound web services to function off of any of the static NAT statements.
Both outside and inside interfaces go up/up and run clean - although the outside interface does attach to a hub at 10 / half.
sh run
: Saved
PIX Version 6.3(5)
interface ethernet0 auto
interface ethernet1 auto
nameif ethernet0 uunet security0
nameif ethernet1 inside security100
enable password xxxx
passwd xxxx
hostname xxxxxx
domain-name xxxxxxx
fixup protocol dns maximum-length 512
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol tftp 69
names
access-list uunet_in permit ip any any
access-list uunet_in permit icmp any any
access-list inside_out permit ip any any
access-list inside_out permit icmp any any
pager lines 24
mtu uunet 1500
mtu inside 1500
ip address uunet 1.2.3.2 255.255.255.0
ip address inside 10.2.0.1 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
pdm history enable
arp timeout 14400
global (uunet) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
static (inside,uunet) 1.2.3.11 10.2.0.11 netmask 255.255.255.255 0 0
static (inside,uunet) 1.2.3.12 10.2.0.12 netmask 255.255.255.255 0 0
static (inside,uunet) 1.2.3.13 10.2.0.13 netmask 255.255.255.255 0 0
access-group uunet_in in interface uunet
access-group inside_out in interface inside
route uunet 0.0.0.0 0.0.0.0 1.2.3.1 1
route inside 10.2.0.1 255.255.255.255 10.2.0.200 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout sip-disconnect 0:02:00 sip-invite 0:03:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server TACACS+ max-failed-attempts 3
aaa-server TACACS+ deadtime 10
aaa-server RADIUS protocol radius
aaa-server RADIUS max-failed-attempts 3
aaa-server RADIUS deadtime 10
aaa-server LOCAL protocol local
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
telnet timeout 5
ssh timeout 5
console timeout 0
terminal width 80
: end
gecko2207 Mon, 11/12/2007 - 11:51
Can you access the internet from inside? Also, where are you trying to access the outside IPs from? Are you plugged into the hub in front of the firewall or are you on the inside network trying to access via the public IPs?
Brandon
asafayan Mon, 11/12/2007 - 12:07
Internal access to the web wouldn't work b/c DNS would fail when I would integrate this firewall. It would instantly start working when I try the original firewall that his one is replacing.
External access was attemped from another Internet connection - not the hub.
gecko2207 Mon, 11/12/2007 - 12:30
Can you ping the external IPs from the Internet when the PIX is plugged in? They are the same IPs as on the old firewall correct?
asafayan Tue, 11/13/2007 - 11:40
The external IPs aren't pingable and they match exactly the previous firewall's IPs.
I was wondering if it might be the ARP cache on the edge router sitting in front of the firewall. I did ping from the firewall to the inside interface of the edge router successfully.
