Voice vlan in 2950 ios switch
Answered Question
Nov 12th, 2007
hello
we have configured a switch IOS (tm) C2950 Software (C2950-I6Q4L2-M), Version 12.1(13)EA1 , and i noticed that u cant configure voice vlan before trunk that port.
Is there any newer ios version which is release me that trunking or we need new switches ?
thanks
Correct Answer by uniemeyer about 9 years 6 months ago
We have IOS
12.1(22)EA6
running and that works without setting the port in trunking mode.
regards
Correct Answer by Rob Huffman about 9 years 6 months ago
Hi Bill,
Excellent question. We have used many 2950's through the years and did discover this limitation when working with Voice Vlans. We have never found a workaround that enabled us to not have to use the (switchport mode trunk) config as you can with newer switch models.
Hope this helps!
Rob
Overall Rating: 5 (4 ratings)
Correct Answer
Rob Huffman Tue, 11/13/2007 - 07:41
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Bill,
Hope this helps!
Rob
Correct Answer
uniemeyer Tue, 11/13/2007 - 13:43
We have IOS
12.1(22)EA6
regards
Rob Huffman Wed, 11/14/2007 - 05:43
  • Hall of Fame,
    Founding Member
Hi Ulrich,
Nice find on this one :) I'll have to lab up a 2950 and give this a try. 5 points for your good support here!
Thanks again,
Rob
