verification of the layer 2 connection
Nov 12th, 2007
we're creating an etherchannel between the two 10GE ports on the 6509's and I was wandering if there were a conclusive way to verify that the Layer 2 was working between these switches? I was thinking of may be pulling the cable off one of the switches or something like that...
thanks..
bvsnarayana03 Mon, 11/12/2007 - 23:49
  • Silver, 250 points or more
show etherchannel [channel-group] {port-channel | brief | detail | summary | port | load-balance | protocol}
Syntax Description
channel-group
(Optional) Number of the channel group; valid values are a maximum of 64 values from 1 to 282.
port-channel
Displays the port-channel information.
brief
Displays a summary of EtherChannel information.
detail
Displays the detailed EtherChannel information.
summary
Displays a one-line summary per channel group.
port
Displays the EtherChannel port information.
load-balance
Displays load-balance information.
protocol
Displays the enabled protocol.
dinesh_mih Thu, 11/15/2007 - 03:59
HI,
you can issue show eth sum command and check that both the interfaces are being shown as UP. If they are showing up then you cna be sure that ether-channel is working fine. In order to finally chekc the things plug out one cable and see if networks keeps working fine. You can issue a ping and see while plugging the cable out that ping response is not broken. I will recommend to do this testing during off hours to avoid any issues.
Dinesh
http://Knowurtech.com
(Good technical articles. Submit your articles and get featured on our website. Send email to [email protected]. To know the benefits http://www.knowurtech.com/be_an_expert.html)
HI,
Dinesh
