IPM in LMS3.0 problem with Source device
Nov 12th, 2007
Hello, I have a problem with device source, when I want to create the collector the device source do not appear but in the target yes, Why?. I import the device no problem.
regards
Guillermo
Joe Clarke Mon, 11/12/2007 - 16:25
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
What type of device? What version of IOS? For a device to be a valid source, it must be running a supported version of IOS with the IP SLA feature, and the SNMP credentials must be correct. To verify the credentials are correct, use Management Station to Device under Device Center.
g_curuchaga Mon, 11/12/2007 - 16:34
Hello, Router only, but When I import device, I can see the device target buy I don't see the device source. then I can not create the collector. The credentials are correct.
Type Software Version
c2610 12.1(5)T9
c1841 12.4(12b)
c2801 12.4(10b)
c2610 12.1(5)T9
c2801 12.3(11)T7
c2610 12.2(11)T11
c2801 12.3(8)T11
c2801 12.3(11)T7
c2610 12.1(5)T9
c2801 12.3(8)T11
c2801 12.4(10b)
c2801 12.4(10a)
c2610 12.1(5)T9
c2620 12.1(5)T9
c2610 12.1(5)T9
c7206VXR 12.3(23)
c2801 12.4(10a)
regards
Guillermo
Joe Clarke Mon, 11/12/2007 - 16:42
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
You're seeing this problem for all of these devices? Go to IPM > Collector Management > Devices and expand the "All Devices" box. Post a screenshot of that showing at least one specific device that you are not seeing under your list of available Source devices.
