WCS sync to Controller
Nov 12th, 2007
I have a WCS v 4.0.96 which controls 3 WLC boxes. Suffice it to say there have been too many hands in the WLC making changes. How do I go about synchronizing my WCS to the controllers to make sure they all are in agreement with each other?
Overall Rating: 5 (1 ratings)
rthoward Tue, 11/13/2007 - 17:48
Not sure for your version; but, in version 4.2.62.0 you do the following:
- configure
- controllers
- in the drop down box on the right select 'save config to flash' to make sure everything is saved first
- put a check in the boxes to the left of each controller to apply
- then click the 'go' button on the right
--- when that completes
- select the option to 'refresh config from controller' in the drop down box
- select the contollers to update from
- click 'go' button
respond as needed to additional messages
I hope this helps.
rochoa8aeg Wed, 11/14/2007 - 11:13
Great, will try it. One more question though, If changes were made using WCS, and different changes were made on a WLC, during the 'Refresh Config from Controller', which changes will take precedence? Will I overwrite any changes I made with WCS?
