Cisco Switches/Routers and Avaya VoIP phones
I recently inherited a small Cisco network that is using Avaya VoIP phones. Since the previous administrator knew nothing about networks, everything was configured in 1 large VLAN. Now, I am trying to move the phones over to a 172.16.128.x/24 VLAN to seperate voice traffic from data traffic. the general switch (a Cisco 3750) port configuration is this:
interface FastEthernetx/x/x
switchport access vlan 128
switchport trunk native vlan 128
switchport mode trunk
switchport voice vlan 130
load-interval 30
mls qos trust cos
no cdp enable
spanning-tree portfast
spanning-tree bpdufilter enable
Once you configure the port with the above settings and reset the phone, the phone does come up on it's new IP settings (on the 172.16.130.x/24 subnet) and works fine, as does the PC. But before you reset the phone if you add the above port configuration and just reboot the phone (not do a reset), the phone comes back on it's older 172.17.x.x/22 IP settings and works just fine. Routing between VLAN's is done off of the 3750 on a subinterface configured on a 3745.
So my question is, since the phone seems to be pulling from DHCP and "then" pulling an IP address from the Avaya server (on the 172.17.x.x/22 subnet), why would it work on a subnet (172.16.130.x/24) for which it does not have an IP?
I'm no Avaya or VoIP expert (but i'm working on it), so I wanted to see if someone with more experience might know. Thanks.
n.rungjitwaranon Mon, 11/12/2007 - 19:22
I'm not sure about your network configuration but from my experience with Avaya phones, you need only these commands;
interface fax/x/x
swithport trunk native vlan [data vlan]
switchport trunk allowed vlan [data,voice] ! optional... just limit your broadcast domain.
I think the command "switchport voice vlan" just works with Cisco phones because it uses CDP to detect voice VLAN.
The rest of the configurations could be added manually on your Avaya phones or in the DHCP scope option number "176". You can add the following parameters in the scope option;
MCIPADD; C-LAN IP address(es)
MCPORT; default is 1719
TFTPSRVR; TFTP server (for upload phone's firmware)
L2QVLAN; Add your voice VLAN here.
i.e. option 176: MCIPADD=172.17.x.x,MCPORT=1719,L2QVLAN=130
And dont forget to relay your DHCP queries in your voice VLAN to the correct DHCP server.
interface vlan [voice VLAN]
ip helper-address 172.17.x.x
