http forward step to .jsp just displays a blank page (UCCX5.0)
Nov 12th, 2007
  • Bronze, 100 points or more
Anyone,
I have a .aef script that captures the stats from a couple of CSQs. (Agents logged in, Calls in Queue, etc).
I have an http trigger that starts the script. All works great, as debugger shows this to be the case.
The final step is an http forward step to a .jsp file, which is supposed to display the stats and refresh every 10 seconds (by referencing the http trigger of course).
I had this working a couple of years ago on UCCX4.0, but this is the first time with UCCX5.0.
I know the .jsp file is in the correct place, uploaded using Document Management (webapps\ROOT).
The IE 6.0 just displays a blank window.
Brilliant.
Any ideas?
If I get it working, I will post the .aef and .jsp scripts as a reward.
Chris
sbilgi Fri, 11/16/2007 - 12:31
  • Silver, 250 points or more
As per the document http://cisco.com/en/US/products/sw/custcosw/ps3651/products_qanda_item09186a008021df8d.shtml, you can contact any of these in order to receive assistance with IVR custom scripts:
1) Contact your local Cisco Partner or Cisco Advanced Services (available via your local Cisco Account Team).
2) Contact Cisco Developer Support.
3) Contact this email address: [email protected].
As per the document http://cisco.com/en/US/products/sw/custcosw/ps3651/products_qanda_item09..., you can contact any of these in order to receive assistance with IVR custom scripts:
cogden Wed, 11/21/2007 - 08:31
Didn't get this working, and the conclusion is that with UCCX5.0 I think the IIS functionality is not there/enabled to be able to activate .jsp code.
We have decided to get one of our application developers to write a .aspx application that is able to pull the relevant stats directly from the SQL2000 database.
So I have given up on the .jsp route to display these types of statistics on UCCX5.0 for now.
Chris
6rmisior Wed, 01/09/2008 - 08:50
Looks like you are running into BUG: CSCsl90375
So far there is no fix for it but you can convert your .jsp to a servlet.
Hope it helps!
Robert
kpranger1 Tue, 09/30/2008 - 11:05
Robert,
This helps out as I have been unable to resolve the blank screen. Do you have a good way to convert the .jsp file to servlet?
Thank you,
Keith
