VPN tunnel permanently UP
Nov 12th, 2007
I have an ASA 5510(HQ)running ezvpn server and ISR2811(REMOTE) running ezvpn remote client
I would like to know how is it possible to keep the tunnel up 24 7, i left the connection on for 24hours, every morning remote users will complain that the tunnel is down,
I need the connection to be up 24 7 as we have IP phones with internal extensions at Remote office that we can reach from HQ. Centralize call-processing done at HQ
I tried the crypto isakmp keepalive 20 10 command on the ISR, but it does nothing.
PLz advice
dradhika Mon, 11/12/2007 - 20:52
Have you tried these options under group policy?
vpn-access-hours - Restricts VPN access hours.
vpn-idle-timeout - Specifies the number of minutes a session can be idle before it times out.
vpn-session-timeout - Specifies the maximum number of minutes for VPN connections.
ajagadee Tue, 11/13/2007 - 07:30
Are you using PAT or NEM mode on the EzVPN Client.
