Overlapping IPSec Tunnel between an ASA and Router
Nov 12th, 2007
Please help, this is really an emerrgency
I've gone thru 7 cisco techs (escalation team, backbone team, etc., etc,) and no luck.
Network behind ASA 7.2 is 10.21.30.0
Network behind IOS 1841 is 192.168.1.0
Packets originating at IOS side and destined to ASA should look to ASA inside hosts as coming from the 10.12.0.0 network.
Packets originating at ASA side and destined to 1841 inside network should be going to the fake 10.12.0.0 network which in turn should go to the real 192.168.1.0 network.
Cisco seems unable to accomplish this for as much as they want to.
The ASA side hasnt been touched, except that has been properly configured for the crypto tunnel and all is well.
The "faking" shuold be done at the 1841 and no matter what they try, it does not work.
The ASA has lots of IPSec tunnels to other networks and one of them includes a 192.168.1.0, so this is why we can't use this to reach the 1841 side from the ASA.
The closest we've been with cisco is that they were able to ping the networks, (1841 side was successfully pinging 10.21.30.x and ASA side was successfully pinging 10.12.0.0) BUT every time they got it this way, inside hosts in the 1841 network were not able to go out to the internet
Please help
dradhika Mon, 11/12/2007 - 20:34
  • Cisco Employee,
Have you tried applying NAT on 1841 for the traffic going from inside 1841 to inside of ASA device?
Radhika
insccisco Mon, 11/12/2007 - 21:15
yes, that is being done. We can NAT anything from 192.168.1.0 to 10.12.0.0 but from there it does not do anything else.
dradhika Tue, 11/13/2007 - 03:56
  • Cisco Employee,
You mean that NAT is working?
When a packet is sent from inside to other end of the tunnel , is there an entry in the translation table?
Radhika
david.barroso Thu, 11/15/2007 - 05:10
I suggest you to use crypto map to apply the NAT on the cisco router. I have done this without any problem in the past.
ASA's side: 172.18.1.0/24
1841's side: 192.168.1.0/24
NAT: 192.168.231.0/24
For example:
access-list 120 permit ip 172.18.1.0 0.0.0.255 192.168.231.0 0.0.0.255
access-list 120 permit ip 192.168.231.0 0.0.0.255 172.18.1.0 0.0.0.255
ip nat inside source static 192.168.1.4 192.168.231.4 route-map NAT
route-map NAT permit 50
match ip address 120
insccisco Mon, 11/26/2007 - 07:26
David, I don't understand. Why do yoi have the statement
I need the entire inside network behind the 1841 router (192.168.1.0/24 in your example) to send requests to the fake 10.12.0.0/24 network (192.168.231.0/24 in your example). This in turn will deliver the packets to the other side of the tunnel (172.18.1.0/24 in your example).
That's is the exact end result that I need: inside network behind the ASA needs to know ONLY about 10.12.0.0 when communicating to the inside network of the 1841 router.
Please help
insccisco Tue, 11/27/2007 - 10:45
I just tried this and it works but the only thing is that it lets me access only one single host at the 1841 side.
So from the ASA side (172.18.1.0/24) I can successfully ping 192.168.231.4 (the fake address). And this is only one way, as I can't ping anything on the ASA side from the 1841 side.
I also tried
ip nat inside source static network 192.168.1.0 192.168.231.0 /24 no-alias
and it works. This of course does not use any route maps and it also seems to mess up my single IP NAT statement which currently NAT my entire inside network to the single public IP address on the outside interface.
any help?
