QoS of Natted Hosts
I can not configure my 3600 to QoS my natted hosts in both directions. It can only limit the download bandwidth but not upload bandwidth.
Details for my config:
version 12.3
service password-encryption
hostname pmsi_qos
enable secret xxx
username admin password xxx
no aaa new-model
ip subnet-zero
ip dhcp excluded-address
ip dhcp pool 0
dns-server 203.189.XX.PO
lease infinite
no ip domain lookup
ip name-server 203.189.XX.XX
ip cef
no scripting tcl init
no scripting tcl encdir
class-map match-any NATTED-HOSTS-IN
match access-group name NATTED-HOSTS-IN
policy-map To-Alpha
shape average 64000
class class-default
shape average 8000
policy-map To-PMSILan
shape average 64000
class class-default
shape average 8000
interface FastEthernet0
description ***PMSI-LAN side***
ip address secondary
ip address 203.189.XX.YY
ip nat inside
service-policy output To-PMSILan
speed auto
interface FastEthernet1
interface Serial0
description *** To Alpha Serial 2/1 ***
bandwidth 2000000
ip address 203.189.XX.YZ
ip nat outside
service-policy output To-Alpha
load-interval 30
clockrate 2000000
ip nat inside source list 7 interface Serial0 overload
ip classless
ip route 203.189.XX.XZ
no ip http server
ip access-list extended NATTED-HOSTS
permit ip host any
ip access-list extended NATTED-HOSTS-IN
permit ip any
access-list 7 permit
access-list 99 permit 203.189.XX.WZ
access-list 99 permit 203.189.XX.AZ
access-list 99 deny any
snmp-server community joshua RO 99
snmp-server enable traps snmp authentication linkdown linkup coldstart warmstart
snmp-server enable traps tty
snmp-server host 203.189.XX.WZ jose
snmp-server host 203.189.XX.AZ jose
line con 0
line aux 0
line vty 0 4
password 7 01190501
login local
guruprasadr Mon, 11/12/2007 - 21:38
HI, [Pls Rate if HELPS]
If my understanding is not wrong,
To apply the QOS on the Interface connected to the Service Provider for limiting the Upload Bandwidth, you need to request the Service Provider to apply the QOS in their interface.
Neverthless, you can limit the Download Bandwidth at Customer Premessis Equipment itself.
Pls Rate if HELPS
Best Regards,
Guru Prasad R
Let me reiterate the problem... My problem is not about the service provider, it is about making the natted hosts bandwidth to be shaped (limited) download and upload. I can limit the download bandwidth to the interface because it can still recognize the private IP address, for the upload you can only limit the bandwidth of the whole subnet because it is NATted (overload) meaning the public ip add can only be limited.
How can I limit the upload bandwidth of my NATted hosts?? Have you guys already tried this one?
