spremkumar Fri, 11/16/2007 - 04:17
  • Red, 2250 points or more
Do make sure that you have identical ios available in the new sup.
AFAIK you can install the same and make sure that its booted up and ready to take over from the current active sup.
you can check out the status of the sup/redundancy usin show module/show redundancy commands.
if you desire to make this new sup to become active then you need to issue forced failover command to make this new sup as active sup.
regds
