11-13-2007 12:13 AM - edited 03-15-2019 07:11 AM
I have heard about a new feature provided by cisco the 3G HWIC card and i'm still unable to get more information about this product as well as if it can be used to voice conversation and not only data.
SO what i'm asking and if it's the case that we can use this release for voice purpose is if we can create a dial-pattern for each card or Sim card i mean if i have two 3G hwic card and i installed two sims and i wanted when i dial a number wich start with 222 it will use the first 3G card to route the call else if i dial 333XXXX it will use the second one? and finally we can just put one sim into each card or there is a way to put more thanks for ur help
Solved! Go to Solution.
11-13-2007 03:32 AM
Correct, at present time cisco does not produce any product to place and received voice call to cellphone networks. As I mentioned, there are many other vendors that do that.
As a recognition to those providing answers, please rate all useful posts using the scrollbox below!
11-13-2007 03:19 AM
the HWIC 3G does not support voice calls, ir can be used for data only.
If you want an interface to GSM that supports voice, there are various vendors doing that with ISDN BRI, analog interface, or even with ethernet and IP.
11-13-2007 03:29 AM
But still there is no solution provided by Cisco For Unified communication that will provide a card wich can handle GSM call (voice) and manage GSM SIM card to allow the issue & recption of voice call via GSM network?
11-13-2007 03:32 AM
