11-13-2007 03:23 AM - edited 03-03-2019 07:31 PM
Please tell me weather router redundancy protocol is available with cisco 1841. In not then from which model it starts.
11-13-2007 03:41 AM
1841 does support HSRP . hope this will suffice your requirement.
rgds
rajat
11-13-2007 03:49 AM
Thanks Rajat, pls send me some doc or link in this regard.
11-13-2007 04:00 AM
Dear Rajat, One more thing if we see this feature in Cisco Product Advisor it shows that only Cisco 3800 series routers have these protocols. Pls help
Suresh.
11-13-2007 05:51 AM
this is what you can do to check
cisco feature navigator->
select hsrp as feature you cant to check-> continue ->
Select platform as 1841->
it will show you all the IOS for 1841 which have this feature available.
rgds
