Disable Corporate Directory on CCM 5.1
m.ranger
Is there a way to remove the corporate directory from the directories? The user should only see the missed calls, answered calls, placed calls and the personal addressbook.
Best regards
Manfred
mattcalderon
Level 4
Level 4
I do know that in CCM 4 you can just change the URL that the directory points to under Enterprise Parameters>Phone URL Parameters>URL Directories. Not sure if the same applies to 5.1
This applies to 5.1 too. But in 5.1 there is a additional Personal Addressbook "behind" the directory button. If I change the url to an undefined link, the corporate directory and the addressbook leaves. My goal is to keep the personal addressbook and delete the global directoy.
