I can`t backup with Disaster Recovery System v6.0
Nov 13th, 2007
I have a CallManager 6.0, 7816. Then I try to backup data but neither with tape location nor with network location I can. With tape location I have read that this server hasn't tape device, only 7835 and 7845 on version 4.
But when I try the second option I can't. I use Serv U FTP as SFTP server.
Any idea? another SFTP server?
Fernando
hadbou Mon, 11/19/2007 - 09:06
  • Bronze, 100 points or more
This issue is documented in Cisco bug ID CSCsj12178, which is superseded by Cisco bug ID CSCsi80320.
The workaround requires remote access to the server.
This issue is fixed in these versions: 6.0(1.1000.14), 6.0(1.1101.2)
Rob Huffman Mon, 11/19/2007 - 09:22
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Fernando,
The one that I have seen recommended the most on these forums is freeftp;
FreeFTP
http://freeftp.com/
Hope this helps!
Rob
