Web Interface problems on BR1310G
Nov 13th, 2007
I have two BR1310Gs and two AP1231Gs.
The 4 pcs I'm using for testing purposes are all running IE6 (various versions) and can all connect to the APs and funtionality on web interface is fine.
However the BR1310Gs are causing problems. On three of the pcs there are javascript errors occuring which means a lot of the functionality of the webpage is absent. i.e. showing associations doesn't list any devices connected (even though there are) and clicking the apply button on other pages does nothing.
An error is reported on the page, being "radio.Array.length" is not an object.
I have upgraded java to the latest but makes no difference.
Spec is below:
AIR-BR1310G-E-K9-R
System Software file c1310-k9w7-tar.124-3g-JA1
System version 12.4(3g)JA1
Boot loader 12.3(2)JA4
PCS
PC1 IE Version 6.0.2800.1106 - Errors occur on pages
PC2 IE Version 6.0.2600.0000IS - Connects and works ok
PC3 IE Version 6.0.2800.1106IS - Errors occur on pages
PC4 IE Version 6.0.2800.1106IS - Errors occur on pages
Whilst one pc works I don't have that particular disk for that particular version of IE, although I don't think it should matter.
drolemc Mon, 11/19/2007 - 09:09
  • Silver, 250 points or more
I think the issue is with the browser. Try uninstalling and reinstalling IE and check if you get the same error. If you end up with the same error then the problem might be with the browser version. Since you have tested with successfully with version Version 6.0.2600.0000IS use that version of IE or try with a different browser.
rcaira Mon, 11/19/2007 - 10:38
Please advise on how to uninstal IE, I don't know of any easy way. Also, spec with the Bridge says to use IE 6 or higher or Netscape 7. Doesn't work with Firefox and Netscape 7 requires higher op system than 2000. In the end I have installed XP Pro on all pcs in an effort to get round the problem. This has worked. Thank you.
