not able to use EAP with ACS 4.1
Nov 13th, 2007
I was trying to setup user authentication via EAP with ACS server. what I did is just follow the configure of the url:http://www.cisco.com/en/US/products/hw/wireless/ps4570/products_configuration_example09186a00801bd035.shtml
Please check my AP configuration:
ISDAP3#sh run
Building configuration...
Current configuration : 2437 bytes
version 12.3
no service pad
hostname SEPISDAP3
ip subnet-zero
no ip domain lookup
aaa new-model
aaa group server radius rad_eap
server 172.16.17.15 auth-port 1645 acct-port 1646
aaa group server radius rad_mac
aaa group server radius rad_acct
aaa group server radius rad_admin
aaa group server tacacs+ tac_admin
server 172.16.17.15
aaa group server radius rad_pmip
aaa group server radius dummy
aaa authentication login default local
aaa authentication login eap_methods group rad_eap
aaa authentication login mac_methods local
aaa authorization exec default local
aaa accounting network acct_methods start-stop group rad_acct
aaa session-id common
dot11 ssid SEP1WLAN
authentication open eap eap_methods
authentication network-eap eap_methods
username xxxxxx privilege 15 password xxx
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption mode wep mandatory
ssid SEP1WLAN
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
bridge-group 1
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio1
no ip address
no ip route-cache
shutdown
ssid SEP1WLAN
speed basic-6.0 9.0 basic-12.0 18.0 basic-24.0 36.0 48.0 54.0
station-role root
bridge-group 1
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
hold-queue 160 in
interface BVI1
ip address 172.16.18.59 255.255.255.0
no ip route-cache
ip default-gateway 172.16.18.1
ip http server
ip http authentication aaa
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
ip radius source-interface BVI1
radius-server attribute 32 include-in-access-req format %h
radius-server host 172.16.17.15 auth-port 1645 acct-port 1646 key sepwireless
radius-server vsa send accounting
control-plane
bridge 1 route ip
line con 0
line vty 0 4
end
after that i did test with "debug aaa authent" trun on on the AP, I got the error msg:
*Mar 1 03:02:22.206: %DOT11-7-AUTH_FAILED: Station 0019.d29e.898c Authentication failed
*Mar 1 03:02:22.303: AAA/BIND(00000035): Bind i/f
*Mar 1 03:02:22.317: AAA/AUTHEN/PPP (00000035): Pick method list 'eap_methods'
SEPISDAP3#
SEPISDAP3#
*Mar 1 03:02:43.839: %DOT11-7-AUTH_FAILED: Station 0019.d29e.898c Authentication failed
*Mar 1 03:02:43.861: AAA/BIND(00000036): Bind i/f
*Mar 1 03:02:11.492: %RADIUS-4-RADIUS_DEAD: RADIUS server 172.16.17.15:1645,1646 is not responding.
*Mar 1 03:02:11.492: %RADIUS-4-RADIUS_ALIVE: RADIUS server 172.16.17.15:1645,1646 has returned.
I am albe to telnet to the ACS server from AP, so there is no network reachability problem. can someone guide me how to reslove the problem?
thanks
bbxie Wed, 11/14/2007 - 18:31
  • Silver, 250 points or more
try to check the logs of the RADIUS server for failed attempts, and the reasons those attempts failed. if no record, then there's communication issue between ACS and AP(check ACS's network configuration for AAA client as showed in the book), if have record, check related configuration accordingly, for example your global authentication setup,user/user group setup, client software config...
Trending Topics - Security & Network
