gateway management via CCM
Answered Question
Nov 13th, 2007
Let me rephraze my purpose from the previous post:
Can CallManager control remote gateway and send to them outbound call to the PSTN and all inbound calls from the PSTN pass through the desired gateway or it's th CM who manager them.
Correct Answer by AJAZ NAWAZ about 9 years 4 months ago
All the calls will be routed from Callmanager to the gateway. The first point of call is Callmanger. Next to the gateway and from there PSTN. So Callmanager is managing how the call should be routed.
For third party billing check out:
http://www.tigercomms.com/english/
hth
Ajaz
pls rate the post if it helps.
Overall Rating: 5 (1 ratings)
Correct Answer
AJAZ NAWAZ Tue, 11/13/2007 - 06:08
  • Silver, 250 points or more
hth
Ajaz
Seifeddine-Tlili Tue, 11/13/2007 - 06:15
thanks for your help so i understood that Cisco doesn't provide a billing solution and by the way can you please provide somes links shown some configurations on how the call should be routed by the CallManager
