PIX 515e ASDM 7.0 Login
Nov 13th, 2007
I am trying to use the 7.0 ASDM after much heartache with the CLI. After doing much configuration on the CLI and then trying to access the ASDM I encounter a username and password window. I leave it blank and it doesn't grant me access. It asks me two more times and then I'm denied.
I then thought that I may have inadvertently changed something so I restored the PIX 515e to factory-default by using the configure factory-default command. After doing this I am still faced with the same problem even though the manual states to leave these fields blank.
Could someone please tell me what is going on here, thank you so much.
JORGE RODRIGUEZ Tue, 11/13/2007 - 14:24
  • Green, 3000 points or more
Hi, I would suggest upgrade Java plug ins to the latest version..I do not see any reason why your're denied access, this is more of a browser/Java issue.
Rgds
Jorge
