LAN has 2 firewall.VPN client issue
Nov 13th, 2007
Lan=192.168.2.0/24
Checkpoint 192.168.2.1 and this is default GW for LAN
ASA=192.168.2.125 - This is configured for Cisco VPN client (Future it may be site to site VPN)
LAN---------Checkpoint------Router1-------ISP1
----------ASA---------------Router2-------ISP2
Cisco client IP pool is 10.1.10.0/24
Check point is configured to redirect any traffic for 10.1.10.0/24 to ASA
Once the VPN client is establish Client cannot pint internal address where as internal can ping client IP.
If i change LAN PCs GW to ASA every thing is OK
That means it only work one way...where do u think i made a mistake ?
irisrios Mon, 11/19/2007 - 10:45
  • Silver, 250 points or more
Once the VPN is established all traffic will be routed through the VPN tunnel . Client might have a different ip address for VPN tunnel. So only ASA to which the VPN tunnel is established will be reachable.
