VRF with Static routes
Nov 13th, 2007
In a 3750 I have 3 vrf, each one with its associated vlans and each one with a static default route to each different gateway, now each vrf need to access a common Vlan (a new web service), how can I accomplish it?
Ip vrf external
rd 100:1
Int vlan 100
ip vrf forwarding external
ip add x.x.x.x
Ip vrf internal
rd 200:1
Int vlan 200
ip vrf forwarding internal
ip add y.y.y.y
Ip vrf partners
rd 300:1
Int vlan 300
ip add z.z.z.z
ip route vrf internal 0 0 x.x.x.1
ip route vrf external 0 0 y.y.y.1
ip route vrf partner 0 0 z.z.z.1
int vlan 500 <-- Common vlan
ip add a.a.a.a
Thanks.
Overall Rating: 5 (1 ratings)
swaroop.potdar Tue, 11/13/2007 - 08:55
  • Blue, 1500 points or more
You can include the common Vlan into a VRF (for eg : central services) run MPBGP for local inter vrf route distribution and you are all set to go.
Here is a sample config.
ip vrf A
rd 100:1
route-target export 100:1
route-target import 100:1
route-target import 100:3
ip vrf B
rd 100:2
route-target export 100:2
route-target import 100:2
ip vrf Central
rd 100:3
route-target export 100:3
int vlan 500
ip vrf forwarding Central
router bgp 1
no synchronization
bgp log-neighbor-changes
no auto-summary
address-family ipv4 vrf B
redistribute connected
redistribute static
no synchronization
exit-address-family
address-family ipv4 vrf A
redistribute static
no synchronization
exit-address-family
address-family ipv4 vrf Central
redistribute static
no synchronization
exit-address-family
HTH-Cheers,
Swaroop
