2 instances of MOH
Answered Question
Nov 13th, 2007
I am running CME on a 2821 and the customer is asking for two separate MOH files based on what number is dialed. I don't think this is possible, but thought I would ask.
Heath
Correct Answer by allan.thomas about 9 years 5 months ago
Within IOS you can only stream MoH audio to a single multicast address, therefore I cannot see it being possible to stream two separate MoH files.
Allan.
Overall Rating: 5 (1 ratings)
Correct Answer
allan.thomas Tue, 11/13/2007 - 08:46
  • Blue, 1500 points or more
Allan.
paolo bevilacqua Tue, 11/13/2007 - 14:47
  • Hall of Fame,
    Founding Member
Are you using B-ACD AA?
If so, that could be doing playing a per-service custom music file to external callers in queue, instead of general MOH. That would not be possible anymore once the extension is reached.
I will consider this feature for a future modification to the script file, would you then be able to test ?
