unable to get site - to site VPN Up
Answered Question
Nov 13th, 2007
i have two PIX runing version 6.3(3) and 7.1(1). Following is my topology and attached config showing running configuration and debugs.
(PC)172.16.10.10/24<-->172.16.10.1/24-PIX(6.3)--1.1.1.2/30---WAN(X-Over cable)---1.1.1.1/30--PIX(7.1)--10.10.10.1/24<--->10.10.10.10/24(PC)
What am i missing?
Correct Answer by elparis about 9 years 5 months ago
By the way, this is the only thing that catches my attention from the 6.3 debugs you provided:
ISAKMP (0): SA is doing pre-shared key authentication using id type ID_FQDN
One thing you can try is to set the ISAKMP identities on both sides:
isakmp identity address (on the 6.3 side)
cry isakmp identity address (on the 7.x side)
Overall Rating: 5 (1 ratings)
elparis Tue, 11/13/2007 - 10:54
  • Cisco Employee,
I don't see anything wrong with the configuration. Nothing seems to be missing.
Could you you enable ISAKMP and IPsec debugging on the 7.x side (debug cry isakmp 128 and debug cry ipsec 128) to get more information of where the IPsec tunnel establishment is failing?
srue Tue, 11/13/2007 - 11:11
  • Blue, 1500 points or more
change the pre-shared key on both ends to something simple and try it again.
I don't see that phase 1 is even completing.
Correct Answer
elparis Tue, 11/13/2007 - 11:12
  • Cisco Employee,
p.holley Tue, 11/13/2007 - 12:24
Entering the following commands solved it:
elparis Tue, 11/13/2007 - 12:30
  • Cisco Employee,
Awesome, glad to see it worked.
Cheers,
Eloy Paris.-
