ASA VPN Tunnel with static policy NAT?
Nov 13th, 2007
I am in the process of configuring a tunnel between our company and an outside vendor. The outside vendor has our same address space in use on their network as well. We had this setup on our existing Nortel VPN equipment and it was working.
I have setup the tunnel as follows:
object-group network DM_INLINE_NETWORK_75
network-object host 172.x.x.129
network-object host 172.x.x.130
network-object host 172.x.x.131
network-object host 172.x.x.132
access-list outside_2_cryptomap extended permit ip object-group DM_INLINE_NETWORK_75 143.x.x.128 255.255.255.128
access-list inside_nat_static_1 extended permit ip host 10.x.x.136 143.x.x.128 255.255.255.128
access-list inside_nat_static_2 extended permit ip host 10.x.x.137 143.x.x.128 255.255.255.128
access-list inside_nat_static_3 extended permit ip host 10.x.x.138 143.x.x.128 255.255.255.128
access-list inside_nat_static_4 extended permit ip host 10.x.x.135 143.x.x.128 255.255.255.128
static (inside,inside) 172.x.x.129 access-list inside_nat_static_1
static (inside,inside) 172.x.x.131 access-list inside_nat_static_2
static (inside,inside) 172.x.x.132 access-list inside_nat_static_3
static (inside,inside) 172.x.x.130 access-list inside_nat_static_4
route inside 172.x.x.128 255.255.255.248 10.x.x.1 1
crypto map outside_map 2 set peer 207.x.x.110
crypto map outside_map 2 set transform-set ESP-3DES-MD5
crypto map outside_map interface outside
crypto isakmp enable outside
crypto isakmp enable inside
crypto isakmp policy 10
authentication pre-share
encryption 3des
hash md5
group 2
lifetime 86400
I was guessing that I needed a static policy NAT since I only want these devices to use this NAT if they are headed over this tunnel.
How far off base am I?
irisrios Mon, 11/19/2007 - 11:40
  • Silver, 250 points or more
Static NAT needs to be configured on ASA if two websites has same range of address. But slowly shift the ip address range and remove Nat statements for better performance.
