ce510; ce565 webcache and javascript in IE6.0
Nov 13th, 2007
When I want doing cache of the intranet files using Microsoft IE6.0, some attributes of javascript like a 'pop-up block' and 'hide a status bar' don't work. If I do the same test with Mozilla Firefox, the javascript works well.
We have done these tests with CE-510; ce565 and WAE-512 with ACNS 5.5.5 software version. The java version is 1.5
Do yo know any solution for this problem?
thanks for your help
smalkeric Mon, 11/19/2007 - 11:41
Go to internet options from tools in internel explorer---> Advanced--> check if the Java is enabled
