IP Communicator through VPN, under Vista
Nov 13th, 2007
I am trying to use IP Communicator through a VPN under
Vista.
The problem is that if I try to use the wireless network
adapter, I receive the error "Could not find the network
adapter needed for registration" and the the IPC closes,
with no option to chose another adapter. The IPC works
fine if I use the wired adapter (But I need the wireless
connection to work).
I have tried both, to select Wired adapter under
Preferences -> Network, and to enter the device name by
hand.
Also, searching through the trace logs i found the
following messages:
Wed Nov 07 17:36:28.879 : EE : ( 5956) -SFB| <--
CSoftFireBoxWnd::verifyMediaRequirements()
Wed Nov 07 17:36:28.879 : ERROR : ( 5956) -SFB| &E
CSoftFireBoxWnd::onCreate(): SFB :
CSoftFireBoxWnd::onCreate : verifyMediaRequirements()
returned ERR_NETWORK_ADAPTERNOTFOUND. Exiting ...
CSoftFireBoxWnd::onCreate(): Caught Exception - Could not
find network adaptor needed for registration : 0
Wed Nov 07 17:36:35.870 : EE : ( 5956) -SFB| <--
My setup is as follows
IP Communicator 2.1.2
Microsoft VPN Client connection
HP Compaq Notebook
Broadcom NetXtreme Gigabit Ethernet
Intel(R) PRO/Wireless 3945ABG Network Connection
(Latest drivers for the adapters)
Windows Vista Business
The same setup under Windows XP works fine.
Any suggestion is welcome!
Ariel
arielroza Fri, 11/23/2007 - 13:50
Thanks! Can you post some details on this bug? The bug toolkit says its contents are not publicly available.
arielroza Mon, 12/10/2007 - 07:24
I saw the bug report, but that bug is only a cosmetic issue. It's not about the problem I am having.
Thanks, anyway.
