QoS for IP Communicator over WLAN
Answered Question
Nov 13th, 2007
Hi, We are in the process of deploying Cisco IP Communicator but we are having voice quality issues when use IP COmmunicator over the wireless...We want to know if the AP 1200 series can be configured for QoS or the configuration has to be done only the switch port level..Thanks in advance..Our laptops are 802.1p enabled. Raj.
Correct Answer by ivillegas about 8 years 11 months ago
Yes, You have the option to configure QoS on Access point 1200 for the traffic between the wireless clients and the access points. For guidelines refer to URL
Overall Rating: 5 (1 ratings)
raj.kennedy Thu, 11/22/2007 - 09:10
thanks...The document says APs supports only downstream(switch to AP) and not upstream Laptop to AP..we are looking for end - to - end QoS solution meaning all the voice packets are marked by the softphone with higher priority and when the access point receives the packets we want the voice packets prioritised and send ..can this be done...thanks,Raj.
