IPMA questions
Nov 13th, 2007
  • Bronze, 100 points or more
Ive got some IPMA questions:
-> how can i (without assistant console) logout from the IPMA Assistant role, in case the Assistant has to go out, like go to the bathroom, so calls will go the Manager?
-> is there any way to change the seconds that it takes, after login or making a call for the screen that appears on the assistant phones screening who the manager is (manager's state info)?
thank you for your help in advance,
Met.
