Configure 2511 as a terminal server
Nov 13th, 2007
I have a 2511 with an octal cable attached to the Async 1-8 port. Config is listed below:
sh run
Building configuration...
Current configuration:
version 11.2
no service udp-small-servers
no service tcp-small-servers
hostname TermServer
enable password cisco
partition flash 2 8 8
ip subnet-zero
no ip domain-lookup
interface Loopback0
ip address 100.100.100.100 255.255.255.255
interface Ethernet0
ip address <address removed>
interface Serial0
no ip address
shutdown
interface Serial1
no ip address
shutdown
interface Async1
no ip address
async mode interactive
interface Async2
no ip address
ip classless
line con 0
password cisco
logging synchronous
login
line 1 16
no exec
exec-timeout 0 0
transport input all
stopbits 1
flowcontrol hardware
line aux 0
line vty 0 4
exec-timeout 0 0
privilege level 15
password cisco
logging synchronous
login local
transport input telnet
end
TermServer#
This is a capture of a session. The problem is that it I can make a connection to the remote device, but I cannot gain control of that device.
TermServer#telnet 100.100.100.100 2001
Trying 100.100.100.100, 2001 ... Open
TermServer#sh line
Tty Typ Tx/Rx A Modem Roty AccO AccI Uses Noise Overruns
* 0 CTY - - - - - 5 0 0/0
* 1 TTY 9600/9600 - - - - - 3 0 0/0
* 2 TTY 9600/9600 - - - - - 2 0 0/0
3 TTY 9600/9600 - - - - - 0 0 0/0
4 TTY 9600/9600 - - - - - 0 0 0/0
5 TTY 9600/9600 - - - - - 0 0 0/0
6 TTY 9600/9600 - - - - - 0 0 0/0
7 TTY 9600/9600 - - - - - 0 0 0/0
8 TTY 9600/9600 - - - - - 0 0 0/0
9 TTY 9600/9600 - - - - - 0 0 0/0
10 TTY 9600/9600 - - - - - 0 0 0/0
11 TTY 9600/9600 - - - - - 0 0 0/0
12 TTY 9600/9600 - - - - - 0 0 0/0
13 TTY 9600/9600 - - - - - 0 0 0/0
14 TTY 9600/9600 - - - - - 0 0 0/0
15 TTY 9600/9600 - - - - - 0 0 0/0
16 TTY 9600/9600 - - - - - 0 0 0/0
17 AUX 9600/9600 - - - - - 0 0 0/0
18 VTY - - - - - 2 0 0/0
19 VTY - - - - - 0 0 0/0
20 VTY - - - - - 0 0 0/0
21 VTY - - - - - 0 0 0/0
--More--
TermServer#
When the connection shows open, pressing return multiple times does nothing. I can only regain control by shift-control 6 -X. Then I do a show line and you can see that I made a connection via the line.
So, the problem is that I am making a reverse telnet connection to the remote device by not gaining control. I have tried 3 different remote devices with different IOSs on them and three different ports on the Async
Overall Rating: 4 (1 ratings)
guruprasadr Tue, 11/13/2007 - 21:35
HI Jeffrey, [PLs Rate if HELPS]
Configuring a Cisco Router as Terminal Server:
when you have a home lab you want to have console connectivity to all your routers at the same time. By using a terminal server (2509-2512 router range) we can accomplish this.
To use a terminal server we need a 2509/2510 8 lines or 2511/2512 16 lines router and 1 or 2 octal cables.
The first thing we do is create a loopback interface that will be used for the reverse telnet sessions from the other devices.
Router(config)#interface loopback0
Router(config-if)#ip address 172.16.1.1 255.255.255.255
Now we add the devices that are connected to this router [octable cable to each console port]
Router(config)#ip host hostname 2001 172.16.1.1
Router(config)#ip host hostname2 2002 172.16.1.1
The previous commands lets you use the hostname of the device to access it on it's console port. The portnumber is made of the following 200x where x is the nr on the octal cable going to that device. Depending on the type of router you use for terminal server you can have either 8 or 16 devices hanging of it.
Now that the router is configured we use the following commands to navigate.
- to access a device
telnet 172.16.1.1 2001
- to switch between active sessions
ctrl-shift-6-x will bring you back to terminal server
show sessions will display the active sessions
entering a number of a session will let you access that session
- to disconnect a session
use the disconnect command
Refer the CISCO Document attached (.pdf) for more help.
Pls Rate if HELPS
Best Regards,
Guru Prasad R
