Router 2507 Ethernet Ports
Nov 13th, 2007
Hi All,
I have a router 2507 series with 16 Ethernet ports, unfortunately it does not appear in the list of interfaces when i typed "Sh ip int brief" command. Can anyone help with why this is so?.
I only have E0 interface appearing out of all.
Secondly can this be used as an Access server?
desai.jaideep Tue, 11/13/2007 - 20:39
As far as I know those ports must be hub ports. They would work as a transparent standalone hub, so you cant do routing between the 2 ethernet ports.
The ip on e0 would be for all the 16 ports.
Also, what is your objective for access server? Pls explain your requirements.
Pls rate if I had been helpful.
JD
