2511 as a terminal server
Nov 13th, 2007
I have a 2511 with an octal cable attached to the Async 1-8 port. Config is listed below:
sh run
Building configuration...
Current configuration:
version 11.2
no service udp-small-servers
no service tcp-small-servers
hostname TermServer
enable password cisco
partition flash 2 8 8
ip subnet-zero
no ip domain-lookup
interface Loopback0
ip address 100.100.100.100 255.255.255.255
interface Ethernet0
ip address <address removed>
interface Serial0
no ip address
shutdown
interface Serial1
no ip address
shutdown
interface Async1
no ip address
async mode interactive
interface Async2
no ip address
ip classless
line con 0
password cisco
logging synchronous
login
line 1 16
no exec
exec-timeout 0 0
transport input all
stopbits 1
flowcontrol hardware
line aux 0
line vty 0 4
exec-timeout 0 0
privilege level 15
password cisco
logging synchronous
login local
transport input telnet
end
TermServer#
This is a capture of a session. The problem is that it I can make a connection to the remote device, but I cannot gain control of that device.
TermServer#telnet 100.100.100.100 2001
Trying 100.100.100.100, 2001 ... Open
TermServer#sh line
Tty Typ Tx/Rx A Modem Roty AccO AccI Uses Noise Overruns
* 0 CTY - - - - - 5 0 0/0
* 1 TTY 9600/9600 - - - - - 3 0 0/0
* 2 TTY 9600/9600 - - - - - 2 0 0/0
3 TTY 9600/9600 - - - - - 0 0 0/0
4 TTY 9600/9600 - - - - - 0 0 0/0
5 TTY 9600/9600 - - - - - 0 0 0/0
6 TTY 9600/9600 - - - - - 0 0 0/0
7 TTY 9600/9600 - - - - - 0 0 0/0
8 TTY 9600/9600 - - - - - 0 0 0/0
9 TTY 9600/9600 - - - - - 0 0 0/0
10 TTY 9600/9600 - - - - - 0 0 0/0
11 TTY 9600/9600 - - - - - 0 0 0/0
12 TTY 9600/9600 - - - - - 0 0 0/0
13 TTY 9600/9600 - - - - - 0 0 0/0
14 TTY 9600/9600 - - - - - 0 0 0/0
15 TTY 9600/9600 - - - - - 0 0 0/0
16 TTY 9600/9600 - - - - - 0 0 0/0
17 AUX 9600/9600 - - - - - 0 0 0/0
18 VTY - - - - - 2 0 0/0
19 VTY - - - - - 0 0 0/0
20 VTY - - - - - 0 0 0/0
21 VTY - - - - - 0 0 0/0
--More--
TermServer#
When the connection shows open, pressing return multiple times does nothing. I can only regain control by shift-control 6 -X. Then I do a show line and you can see that I made a connection via the line.
So, the problem is that I am making a reverse telnet connection to the remote device by not gaining control. I have tried 3 different remote devices with different IOSs on them and three different ports on the Async
Hieu Cao Tue, 11/13/2007 - 17:08
From your ws, have you tried telneting to it without specifiy the port range? ie: telnet 100.100.100.100 without 2001. does it work?
jeffrey.girard Wed, 11/14/2007 - 05:28
from my workstation, I can telnet TO the terminal server with no problems. Once in the terminal server, I cannot reverse telnet to another device. From the terminal server, if I execute the command "telnet 100.100.100.100" without a line number, it works as expected. I telnet to myself and can log in with no issues
Richard Burts Wed, 11/14/2007 - 06:06
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Jeffrey
There are a couple of possibilities that you should check:
- is it possible that the octal cable is not connected on the first set of lines but is connected to the second set? if you telnet 100.100.100.100 2009 what happens?
- is it possible that the device that you are attempting to reverse telnet to is just not responding? If you disconnect the octal cable and connect with a console cable from your PC does the connection work?
- is it possible that the cable is faulty?
Rick
jeffrey.girard Wed, 11/14/2007 - 07:01
Rick -
The sets of lines (and the corresponding physical interface are labelled on the router, but just to be sure, I tried to telnet to 2009 and nothing. Once I clear the line and disconnect the octal cable, I can console to the remote device with no issues. I replaced the octal cable with another and the same thing. I also tried a separate "leg" on the octal cabe going into another device (line 2 going into a switch console port with the same results
Jeff
AJAZ NAWAZ Wed, 11/14/2007 - 06:31
  • Silver, 250 points or more
Try this config:
line 1 16
exec-timeout 0 0
logging synchronous
remove the line 'stopbits 1'
let us know - i'm sure we can get to the bottom of this.
Ajaz
Kevin Dorrell Wed, 11/14/2007 - 06:33
  • Green, 3000 points or more
Try removing the hardware flow control as well.
jeffrey.girard Wed, 11/14/2007 - 07:08
I just tried another test. I added a second octal calbe to the second Async interface and tried to telnet to 2009. Same results. I get a connection but no control. Target machine was a different router from the device connected via line 2001
jeffrey.girard Wed, 11/14/2007 - 07:04
Ajaz -
I added logging sychronous and removed the stopbits 1. No change
AJAZ NAWAZ Wed, 11/14/2007 - 07:12
Jeffrey
Did you match the config which i posted?
Can you please paste here the current config under line 1 16
thanks in advance
Ajaz
jeffrey.girard Wed, 11/14/2007 - 07:16
Ajaz -
Current config under line 1 16
no exec
exec-timeout 0 0
logging synchronous
Kevin Dorrell Wed, 11/14/2007 - 11:36
Here (attached) is the config of my own lab terminal server, which works fine. See if you can spot the difference from yours.
Just a silly thought ... are you sure you are using the right cable from the octal connector to correspond to the TCP port you are trying to access?
Kevin Dorrell
Luxembourg
