VLAN across routers
Nov 13th, 2007
Is there a proper way to route VLAN 100 and 200 from switch1 across routers to switch2 in the scenerio below so that pc2 would acquire vlan100 and 200?
pc1 -> switch1 3560(vlan 100, vlan 200) -> 2811_router1 (eigrp) -> Point-2-Point -> 2811_router2 (eigrp) -> switch2 3650 -> pc2
thanks for your input.
hieu
Overall Rating: 4 (1 ratings)
guruprasadr Tue, 11/13/2007 - 21:27
HI, [Pls Rate if HELPS]
Considering your scenario:
Switch:
VLAN100 - 10.1.0.0
VLAN200 - 10.2.0.0
==> Disable STP feature
>> Create an Interconnection VLAN as VLAN300 (STP enabled) with Subnet 10.3.0.0 ( connecting Switch <---> Router interfaces)
>> Use TAGGING feature (with Up-link Port) to carry VLAN 100, 200 further to other end.
>> Repeat this Scenario at the other side also.
Router:
Go to EIGRP Configuration Mode
>>Advertise as "network 10.0.0.0"
Do Rate if HELPS
Best Regards,
Guru Prasad R
Hieu Cao Wed, 11/14/2007 - 09:24
Thanks Guru for your response. I'll try it out when I've a chance.
hieu
pokwan Sun, 11/18/2007 - 15:32
Guru,
Can you please provide a sample configuration of this?
TIA.
PF
