Backup SSL Cert from ASA
Nov 13th, 2007
I setup my ASA5510 with a 3rd Party Certificate for SSL VPN's. How do I go about backing up this certificate if I have to replace the device? I already have a copy of the config. Is that enough? Thanks.
hadbou Mon, 11/19/2007 - 15:27
  • Bronze, 100 points or more
This is not possible until version 8.0. The "http authentication-certificate" setting will be required to support the "certs" group. This setting will apply to all connections on the configured interface/port.
Phil Williamson Wed, 02/20/2008 - 05:49
Martin - I'm looking for a cert for a 5505. Would you share your experience with obtaining your cert? I asked GoDaddy and they said they did not have anything that would work??
Thx,
Phil
