IPCC Macro runs slow and is inconsistent
Nov 13th, 2007
I was looking for some input on a macro running on the desktop administrator from IPCC Express Premium 5.0. This is a simple macro that changes a screen on a CRM interface, uses Tab to move to a field, pastes the ANI, and submits it.
The macro seems to work; however it is not consistent. It is reliable, in that if you wait for it, it will always work; however, the speed at which it executes is always inconsistent. Occasionally it will run at a, ideal speed, and sometimes it is extremely slow, almost locking the PC up, but it you leave it alone it will always finish.
I have included the macro, which indicates very short delays between the steps - but when it is running slow, these can take one or two seconds between steps to execute them. I am not sure how to troubleshoot this and need to try and figure out a way to get this more consistent.
Has anyone had any experiences with this?
Macro:
[DELAY] 100
[APPLICATION:WMF=SXE TRAINING-TESTING - CITRIX ICA CLIENT]
[DELAY] 150
[CONTROL] 2
[DELAY] 150
[CONTROL] 1
[DELAY] 150
[SHIFT] [TAB]
[DELAY] 25
[SHIFT] [TAB]
[DELAY] 25
[SHIFT] [TAB]
[DELAY] 25
[ENTERPRISE FIELD:ANI]
[DELAY] 25
[ENTER]
Thanks in advance,
Duane Brennan CCIE #15289
