NAT Traversal
Nov 13th, 2007
Hello!!
I just want to make sure of this...
Is NAT-T enable for this IPSec session ?
Below is the Output of the "show crypto isakmp sa detail nat" command...
Can you tell me ? thx :)
UACA-VPN#show crypto isakmp sa detail nat
Codes: C - IKE configuration mode, D - Dead Peer Detection
K - Keepalives, N - NAT-traversal
X - IKE Extended Authentication
psk - Preshared key, rsig - RSA signature
renc - RSA encryption
IPv4 Crypto ISAKMP SA
C-id Local Remote I-VRF Status Encr Hash Auth DH Lifetime Cap.
2024 201.196.33.30 200.122.146.38 ACTIVE 3des sha psk 2 17:46:11 N
Engine-id:Conn-id = AIM-VPN/SSL-1:24
NAT keepalive(sec) 0
In local 201.x.x.30:4500 remote 192.168.20.15:4500
IPv6 Crypto ISAKMP SA
UACA-VPN#
Overall Rating: 4 (1 ratings)
thult Wed, 11/14/2007 - 00:54
UDP Port 4500 indicates NAT-T. Without NAT-T it should use UDP port 500.
