6500 VRF aware NAT
Nov 13th, 2007
In an Enterprise Network we are using CAT6500 SUP720/MSFC3B with VRF Lite.
According to the Software Advisor VRF aware NAT is not supported on the 6k. But I think with the MPLS image it should be supported.
My question: Is it supported and if yes whats the recommended image if i just want to have vrf-lite with vrf aware NAT - no MPLS
cheers
patrick
swaroop.potdar Thu, 11/15/2007 - 08:24
  • Blue, 1500 points or more
IF you have a FWSM then you should be good to go for the VRF-Aware NAT. I am not aware of NAT being performed natively on the SUP.
HTH-Cheers,
Swaroop
