External posture validation server LanDesk vs. ACS
Nov 14th, 2007
I want you to ask wheather somebody has same problem as me and how did you solve it.
I want to validate security of hosts with LANDesk® Security Suite 8.7 in cooperation with ACS. My problem seems to be in comunication between ACS and LanDesk validation server. Landesk server in log says that no scan has been made on the host. But when i dont forward LanDesk credentials to LanDesk and I Validate them on ACS, it works. I mean ACS can determine whether the scan has been made and with which result.
So I think problem isn't in CTA or LanDesk host agent(when they send right credentials). It seems to be somewhere between ACS and LD server.
Didn't you have similar problem?
p.s. I have been imported LanDesk plugins into CTA and attributes definition file into ACS. But I am not sure if the External posture validation setup in URL field should be "http://ip.a.d.d:12576/pvs.exe" which i found in LD documentation. In google i found another URL "http://ip.a.d.d:12576/avp.exe". None of them works properly. And on LD server isn't such a file.
Thans for help
Daniel Sebek
