11-14-2007 03:02 AM
One of my 6500 MSFCs has a number of these virtual interfaces configured - though there are no associated interface configuration commands.
I can't find any explanation about what these are for on CCO. I strongly suspect that I can delete them, but I have to be sure.
Can anyone help?
11-14-2007 03:28 AM
virtual tokenring interfaces are typically used in an environment where snasw is used.
Historically this was/is the entry point when you have physical tokenring interfaces and you srb into the virtual tokenring and then you define the virtual tokenring interface as a snasw port. Can also be used with srtlb and physical ethernet.
The downstream appn/sna devices would then connect to the mac address defined on the virtual tokenring interface.
To make a long story short a 6500 msfc does neigher support physical tokenring interfaces nor snasw.
So as long as there is no other configuration on your system. Something like a dspu might be able to use the vtok, then you can simly delete the vtok interfaces.
thanks...
Matthias
11-14-2007 03:32 AM
Thanks for your advice Matthias.
Kind regards,
Huw
