Text Editor to compare between two configuration files
Nov 14th, 2007
We used to "copy and paste" configuration from a txt file. Sometimes I need to compare between the configuration's txt files and the output of the "show running-config" command.
What is the recommended (powerful) text editor that can be used to compare between a configuration txt file and the output for "show running-config" command, specillay when we have got the configuartion file with too many lines of configurations.
Overall Rating: 4 (2 ratings)
glen.grant Wed, 11/14/2007 - 04:43
Use Compare It " , it is a tool used exactly for that , not sure if it costs anything.
