SSL (SVC) VPN large packets
networkdvd
In the ASA log, we are seeing the following error:
Error Message %ASA-3-722036: Group group User user-name IP IP_address Transmitting
large packet length (threshold threshold).
I presume our server is sending large packets to the SSL client? Has anyone else encountered this?
Mark.
irisrios
Level 6
Level 6
This error message means that client is sending packets larger than the level expected by ASA. Change the MTU on the client side. This URL should help http://www.cisco.com/en/US/docs/security/asa/asa80/command/reference/s8.html#wp1318649 for more information.
Thanks for the reply. Unfortunately I am not using the AnyConnect client. I am using ASA 7.2 with the SVC client.
bcoverstone
I know this post is 5 years old, but this problem is still cropping up from time to time with no explanation.  Specifically, myself and others have an issue with a large packet length of 1410, with a threshold of 1406.  Unfortunately, you can't change the MTU because the maximum is 1406.  This doesn't even make sense.
I did find one possibility.  A troubleshooting article showing the ASA transmitting packets that exceeded the MTU could be fixed by running:
   svc compression none
But will this also fix the received packets?
Hi Brian,
The old SSL client is not longer supported, it is legacy.
At this point, I would suggest the AnyConnect client, since it introduces the command:
[no] svc mtu size
Which only affects the AnyConnect sessios. The old SSL VPN Client (SVC) does not suppor it.
An example:
ASA(config)# group-policy AnyConnect attributes
ASA(config-group-policy)# webvpn
ASA(config-group-webvpn)# svc mtu 1200
Thanks.
Portu.
Please rate any helpful posts.
