PC can't ping downstream networks
Nov 14th, 2007
I have an ASA5505 and have setup rip v2 on it. I have some downstream routers set up connected off one of the ASA switchports
ASA(INSIDE) --- --- etc
From the ASA i can ping any where but from the PC i cannot ping the network even though the Gateway router is directly connected and has that route.i can ping the ip only
Debugging shows:
Nov 14 2007 21:49:34: %ASA-3-106014: Deny inbound icmp src inside: dst inside: (type 8, code 0)
Nov 14 2007 22:25:56: %ASA-3-106014: Deny inbound icmp src inside: dst inside: (type 0, code 0)
There is no acl's on the router from the LAN and all seems correct from the client.
ICMP inspection is enabled.
Am I missing something. Software release is ver 8.0(2)
