Richard Burts Wed, 11/14/2007 - 05:54
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Gerhard
Try configuring a trunk on the switch that includes that VLAN.
Ric
rsohi Wed, 11/14/2007 - 08:11
Hi Gerhard, try the following commands:
int vlanXXX
vlan XXX
I have used this in the past and it tends to bring the vlan ints up.
regards,
Raj
config terminal
interface Vlan1
ip address 192.168.0.1 255.255.255.0
no autostate
no shutdown
interface Vlan2
no autostate
no shutdown
interface Vlan3
ip address 192.168.2.1 255.255.255.0
no autostate
no shutdown
int range FastEthernet0/1 - 8
switch access vlan 1
switch mode access
int range FastEthernet0/9 - 16
switch access vlan 2
switch mode access
int range FastEthernet0/17 - 24
switch access vlan 3
switch mode access
end
produces the following results with all ports unplugged.
jedavis Wed, 02/06/2013 - 07:38
What IOS version supports the autostate command?  I just loaded 15.0(2)SE IP base on a 3560v2 and this interface command is not available.
-Jeff
mahmoodmkl Wed, 02/06/2013 - 19:46
  • Gold, 750 points or more
i think u have ti type it
