RME 4.0.5 - FWSM with multiple context - config archive
Nov 14th, 2007
Hi all
Is it possible to make config archive from multiple context FWSM with RME in CiscoWorks?
RME reports config archive successful and Debug has no errors. RME is successfully making config archive from one context and the system context. It seems not to notice the other contexts.
The Device in question:
Cisco Catalyst 6000 FWSM (Multiple Security Contexts)
Current setup:
LMS 2.6
RME 4.0.5 + Catalyst 6000 IOS Switch Series Package.
Any suggestions or ideas?
Andri
yjdabear Wed, 11/14/2007 - 06:56
  • Gold, 750 points or more
There's a footnote on that:
http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_resource_manager_essentials/4.0.3/device_support/table/RME403SI.htm
"5. After adding the device into the DCR, and whenever the device is switched between the Single and Multi Security Context Modes, the device should be deleted and added again into the DCR. This is due to change in the sysobjid and also because the number of configurations for the device varies when there is switching between the modes."
